Disable keyboard shortcut
Add a way to disable (or/and change) the keyboard shortcut.
I keep accidently hitting it and it’s annoying me.
@Xiarno
Sorry for the issue. Thanks for your feedback on adding a way to disable our chosen keyboard shortcut.
In addition to the ability to disable the shortcut it would be nice to allow you to change it to something else.
I will discuss with our team if this can be done in a reasonable way for Windows 10/11. Thanks for your feedback everyone!
Some people have asked to use the default Task Manager keyboard shortcut, so giving users the ability to make their own could be useful.
I would really not want AppControl to take over Ctrl-Shift-Esc (Task Manager’s shortcut)!
The original requests from AppControl users was to take over that shortcut, but we decided that could cause some bad scenarios so that’s why we chose not to do that. Some people still request to take over that shortcut and have even used third party tools to do so already.
Opened three time AppControl by accident today, because of the keyboard shortcut. Still don’t know which keys combination it is… A way to disable it would be appreciated !
The shortcut is Win+Ctrl+A and we put it in our settings at the top in case someone forgets it. It’s on our roadmap to allow keyboard shortcut customizations, including just turning it off completely. Sorry for the issue.
