while the other post stated problems of seperate disk io per app, my request is straight forward and simpler: add another major tab called partition IO, with no app breakdown.
@Michael thanks, this is an interesting idea. Our team will discuss adding an additional optional tab called partition IO, where there is no per-app usage data that causes us a complexity issue.
Are you saying it’s just a large graph, and then if you mouse over it shows the breakdown per partition?
have a new major tab:
- the list below (where apps are in the other tabs) you have all partitions you found
- if none selected, the graph show the grand total
- if one is selected, the graph shows only the amounts over time for the selected partition
TXs and cheers
Michael
