Enhancement request: more visible indicator for running apps
I like the triangle that shows apps that are currently running, but the icon is really tiny. It might be useful to make it much bigger so you can tell at a glance those apps that are running.
Thanks for your consideration.
BTW - I really like AppControl and I will be demoing it to my user group (Ottawa PC Users’ Group - https://opcug.ca/)
@CTaylor thanks for including us! We will consider how to make it more obvious an app is actively running vs not, thanks for your feedback.
