Incorrect CPU Temp Reported
Hi there,
Love this app. Only issue I’ve found so far is incorrect CPU temp being reported. See my screenshot below. My CPU model is AMD Threadripper PRO 9945WX. Keep up the good work!
@loganr95
Yes, that’s a big difference. We’ll see if we can reproduce this and double check if our temp is right or wrong. Thanks for using AppControl!
amazing app, similar issue AMD RYZEN 9 9950x3d on a GIGABYTE X870E AORUS ELITE WIFI7 Motherboard
Reported to our team, thanks!
@jrbuzzer our team asked if you are using our latest version if you go to the top right menu and choose “About” is it the same as at www.appcontrol.com under our download button?
Just checking in on this issue? Do you have our latest software? I ask because we fixed a similar issue recently on one of our updates AppControl Changelog.
