I would like to suggest center click scroll wheel dismisses notification, just like windows notifications, to make it a little more cohesive
@NonMuss I did not even realize that I could dismiss a Windows notification by clicking the center mouse scroll wheel, thanks! I will try it next time this comes up for me.
Also, FYI, if you did not realize it… our notifications do disappear on their own after a few moments. I will see if we can use the center mouse scroll wheel to dismiss our own notifications.
I’m happy to see someone had the same idea.
In reality, many notifications sometimes appear (often following an update during which many executables are modified or installed), having a fairly large unusable area can be annoying depending on the task I am doing.
I had also thought about using the middle click to quickly dismiss all notifications, knowing that their height is never the same.
@DeepWhippet so you are suggesting it not dismiss individual notifications, but all notifications? I guess we could make a setting to control that. We are investigating, thanks!
We plan to have this implemented in the next release, thanks!
This is now done on our latest update.
