The description for “Cursor.exe” (by Anysphere) is incorrect. It says it’s a mouse cursor customizer, but it’s actually an AI code editor.
I’ve attached a screenshot showing the issue.
Wow, that’s a bad miss. I fixed it:
cursor.exe from Anysphere Inc. is the main executable for Cursor, an AI-powered code editor (IDE) used for programming. It’s basically a development tool (similar to VS Code) that uses AI to write, edit and understand code automatically.
It takes a while to update on your end, sorry for the delay, but others will see the updated info. Thanks for reporting this issue.
